Routing HSR fuel lines on Carb car
Old Dec 9, 2003 | 10:13 AM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I'm swapping from a carb to an HSR and have a question. I see that people sell kits to connect the stock TPI fuel hard line to the HSR fuel rail. Would one of these kits also work to connect the fuel rail to the stock carb hard line? So basically waht I'm wondering is if the hard lines have different ends on them between tpi and carb cars, I realize I will have to route it differently b/c the lines run down opposite sides of the car. Thanks for any help!
Old Dec 9, 2003 | 10:36 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
No. You will need hard line to -6 inverted flare adapters. The TPI kits are made to be threaded into the stock hoses, which you don't have. Don't forget you will need a return line if don't already hava one.
Old Dec 9, 2003 | 10:51 AM
Car: 1986 IROC-Z28
I have a return line, carb'd cars came w/ them to avoid vapor lock. Thanks for your help!
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
