Urgent Question
Old Dec 22, 2003 | 01:11 PM
ULTM8Z's Avatar
Urgent Question
My idle misfire is back (has been back for a few days now).
I downloaded a EFI circuit diagnostic check for 7730 ECMs from the site DIY-EFI and it says that with the engine running I should see 2.3V at the distriubutor reference terminal at the ECM. IT's the purple with white stripe wire at pin BD8 (circuit #430).
Since I'm only showing 0.6V there, I'm wondering if I have a problem.
Does anyone know off hand if this is indeed a problem. Or ayone with access to their 7730 computer, could you take a voltage check at that terminal and let me know what you get??
Thanks very much in advance!
Old Dec 23, 2003 | 12:53 AM
ULTM8Z's Avatar
Anybody???
Old Dec 24, 2003 | 04:44 PM
ULTM8Z's Avatar
Guys, I could really use some help on this. Looks like 40 people have viewed this post... is there anyone who can do a quick check for me??
Old Dec 27, 2003 | 09:48 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I wish I could help. Bump to top for you.
Old Dec 28, 2003 | 05:52 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
magnetic pick-up coil output voltage
Utm8Z,
Not sure how much help this is, I'll not be able to check the ouptut on my dizzy until Monday 12-29-03, but check out this page on the subject of coil output voltage amplitude.
Hall-effect sensor waveform
The square wave when monitored on an oscilloscope may vary in amplitude, this is not thought to be a problem as it is the frequency that is important, not the height of the voltage.
Although this maybe true I wouldn't want to be an exception to the average output of other dizzys, and it may be that the ignition signal amplifier requires a minimum voltage (maybe .6 volts is slightly below minimum) to recognize it as an valid ignition pulse. I would prefer the ~2volts stated by DIY-EFI.
Since the GM HEI uses a Hall-effect switch this is a good example.
Other sensor waveforms can be found at Pico ADC212 PC Parallel Port Virtual Oscilloscope
Her's another page that talks about distributor pick-up coils.
Tech Tips
Old Dec 28, 2003 | 09:44 PM
ULTM8Z's Avatar
rgarcia63,
Thanks much! I'll look forward to your results.
I took a look at that Hall Effect article. Interesting, but I'm not sure it really offers up any new avenues for me to pursue. I'm really close to buying a brand new wiring harness and rewiring the EFI system.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
