iac
Old Dec 26, 2003 | 11:01 PM
Ron22's Avatar
Car: Trans Am -90
iac
I have a problem that my engine got so much fuel that its hardly run.
I have check almost everything and i wonder, is there a way to measuerment the iac like you can do with the tps sensor in volt?
And if so, how many volts should the iac have?
Very thankful for answer and ideas.... Ron22
Old Dec 26, 2003 | 11:26 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
For the 86 IAC you check the resistance across the IAC coils. The reading should be more than 20 ohms between the terminals that are across from each other.
Whatever you do, don't purt 12 volts to the IAC, that'll kill it.
Give me some details on what the engine is doing.
Hope this helps.
Jake
Old Dec 26, 2003 | 11:43 PM
Ron22's Avatar
Car: Trans Am -90
Thank you so much... i will check how many ohms i have, i had no idea about this, so that was a really good advice..... Ron22
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
