Knock operation?
Old Dec 31, 2003 | 09:09 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Knock operation?
Yo,
I was at work the other day and was playing around trying to figure out my silly little problem with what I believe to be false knock.
Anyway, I decided to try to test the sensor and/or knock module. Maybe my little cheesy test won't work, but here's what I did.
I hooked up scanner so I could see knock counts and spark retard. I turned key on, of course if scanner is working, and tapped the block near the sensor. I would have thought I would at least have gotten a knock count if not any spark retard. I got nothing from either. I tried tapping the block in various places with varying things to make different tones. Nothing.
Does this sound right to any of you? Should I not have gotten some amount of knock count? I think I should...
Thanks...
Old Jan 1, 2004 | 01:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd have thought you would have showed a knock...infact I belive the test you did is in my Helms manual.
Old Jan 1, 2004 | 01:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Well, I thought it would have worked as well. I am glad to hear that the test may even be an appropriate procedure. I had talked to a few other people about it and they all thought it should show something too.
Thanks.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
