YES, 305 build up: heads, cam, stall etc.
Old Jan 3, 2004 | 01:50 AM
onebadassbird's Avatar
Car: 91' Trans Am
I have a 91' Trans Am with Ram Air, SLP runners, Edelbrock baseplate, 22lb injectors, AFPR, Headers, etc etc. Besides the bolt ons, its a pretty much stock engine. I know all the B/S that goes along with working a 305 but under my circumstances, I decided to keep it. The car will not be a daily driver so im not worried about mpg or anything like that. Money is not a HUGE option. I will be taking the engine out this summer and I plan on spending as much time as it takes to build it up.
I was looking for a good combo of heads, cam, and stall that would give me some good grunt on the low end. I was looking for a nice pair of alumminum heads, and maby a good cam kit to go along with it. If anyone has any input or someone did a similar build it would rock to hear what you think.
Old Jan 3, 2004 | 09:42 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
My combination work very well (check my sig) but it does not have alum heads. If you need alum heads you can use the corvette heads, you can also use the E-Tec 170 heads and SDPC base, and you can use the 180CC runner AFR heads with the 1.94/1.6 valves.
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
makaveli09
Aug 12, 2015 09:07 PM
drathaar907
Aug 6, 2015 04:20 PM
