fuel rail question
Car: White KSwisses
Engine: 5.3L Gen III
fuel rail question
I am piecing together a TPI system for swapping a 350 into my 92 RS (305 tbi), and i was wondering which year fuel rails i can use?
Ken
Ken
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by cali92RS
So, even the fuel rails for the LT1's will work?
Do you have a LT1 fuel rail you want to sell? E-mail me at john@lt1intake.com
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you're running an '85-'88 computer and don't want to have to modify the programming you need fuel rails for those years. The 9th injector won't work with a later computer.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I am running a fuel rail from a 88 iroc in my 89 iroc. I took the cold start injector plumping from the back of the rail and had a friend weld the hole in the plug up (not the hole in the back of the rail) and turn the end down a little and re-installed it. Works great!!!!!!!!!
The Trickster!!!!!!!!!!!!!
