Injector question 350/305
Old Jan 4, 2004 | 07:46 AM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Does the tpi 350 engine use the same injector as the tpi 305HO? Is there a marking on an injector to tell the rating?
Old Jan 4, 2004 | 09:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
AFAIK 350's use 22lb/hr and all 305's use 19lb/hr
Old Jan 4, 2004 | 11:10 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The injectors will have either varrying color tops or stripes that will tell you the size.
MustangBeater20
Oct 29, 2022 09:20 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
