Need some help.
Old Jan 5, 2004 | 01:23 AM
80CamaroCab's Avatar
Need some help.
Hello I need som help. I have a l98 from a 85 corvette and a 4 main 350 from a 77 blazer, first which block is best to build on?
Then I have a set of stoc vortec heads, sdpc manifoil,, slp portet plenum and slp runners. I need cam and is this a good cam for my setup.
# Clevite 77 Class III 375hp camshaft new in box
# 16 new Federal Mogul lifters
# Fel Pro cam change gasket kit, including all gaskets for cam change
# Cloyes double true roller 3-key timing kit
# Bottle of Cam lube
Cam specs are as follows
# 292/292 duration
# 480/480 lift
# 230/230 duration @ .050"
# 109 lobe separation
# 1800-5600 rpm power range
# requires headers
# biggest cam available for stock converter
Old Jan 5, 2004 | 01:28 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
either block will suffice, the only diff is one is a 4 bolt main, and the cam its lobe seperation is a little too tight for tpi. You need a cam with at least 112 LSA for it to run well
http://www.compcams.com/Technical/Ca...L/128-169.html
Go there to page 134, to computer controlled hyd flat tappet cams. There is a few choices there
Old Jan 5, 2004 | 12:51 PM
Tanck you, but if I have problems here i Norway to burn aprom, wich cam will you give me advice to bay, or do anyone in here have a prom that will macht this setup.I will also put on a fuelregulator. I also have a th700r4 transmission innstalled, cumputer operated OD. I will also move the airboks to the front of the car so I will get frech/cold air. And I will chance my rotaion to 3.43:1 in the rear end. How many hp and torq will this give me?
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
