I have an 89 IROC L98/700R4 with a 9 bolt 2.73 posi. I currently own, but haven't installed on this car, a set of 1 3/4" SLP (non AIR), a 3" Hooker catback, a Jacob's Prostreet ignition system and have a 3.73 10 bolt posi too.
With the following set up, what rear end gearing would you chose and what stall speed? Keep in mind, this would still be a daily driver, road manners are more important than 1 tenth in the 1/4.
Here's the set up:
Stealth Ram
Trick Flow 23* heads
LT4 Hot Cam
1 3/4" SLP's
3" hooker catback
I'd like to get it right the first time....no swapping major parts, just minor tuning and suspension upgrades.
So what torque converter and rear end?
Here's the set up:
Stealth Ram
LT4 Hot Cam
1 3/4" SLP's
3" hooker catback
Sounds like a nice combination that will make nice power and still have street manners.
Do you have the specs on the heads? Port CCs, flow numbers, combustion chamber CCs; etc?
Jake
Jake
http://store.summitracing.com/partde...30400006%2DCNC
2.02/1.60 195cc intake ports, 64cc combustion chamber.
I don't remember the flow numbers though.
3.73's
2800 Stall
It's a proven setup with the HOT Cam.
Tim
2800 Stall
Tim
