Fuel Injector Sizes
Old Jan 8, 2004 | 07:54 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Fuel Injector Sizes
I have always read that 24# injectors are good for 380 hp. I even did a calculation that showed they were good for that much hp. However, my latest Summit catalog had injectors for sale that stated a 36# injector is needed for 380 hp.
At this point, I can only assume that the injectors were rated at Ford pressures (30#) instead of Chevrolet pressures (43.5#). Which is correct????
Old Jan 9, 2004 | 01:18 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Injectors
Ford's stock non-adjustable preset fuel pressure is 39.7 psi, not much les than Chevy's 43.5 psi.
The 24# injectors are only good for 380 hp if you run them at 85% duty cycle (not a good idea.) You should always go to the next larger injector than you need. In your case I would go with 28#, or 30# injectors @ 43.5 psi.
Old Jan 9, 2004 | 09:23 AM
Captain C's Avatar
Car: 1985 IROC-Z
Thanks!!!!
bryan623
Mar 22, 2021 06:43 PM
toronto formula
Nov 10, 2015 06:17 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
