Fuel System
Old Jan 9, 2004 | 12:07 PM
pontiacpower350's Avatar
Car: 89 Firebird Formula 350
Engine: TPI 350
Fuel System
Alright I know I have a problem with my fuel system. My friend bought this Firebird Formula 350. He had it and it needed a new fuel filter because it kept dying. Then he took it to a shop and it needed new injectors because it kept dying. After all that I bought the car from him. Now every once and a while the throttle will just cut out. Like when im flooring it just stops as if I let completely off the gas. What would you do first. I don’t much about cars except for the basics. Also I refuse to take it to a dealer. It’s a 350TPI.
Old Jan 9, 2004 | 01:48 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
I had the exact problem on my IROC a little while ago. After replacing the VATS, Fuel pump, and relays, it turned out to be the ground wire from the ECM to the distributor. Corrision ate right through it and fried the module as well. I'd pull the cap and have a really good look at the connections and the module itself. if the module looks ok, you may want to , just for the heck of it, get some dielectric gel and re-apply to the module. Thats all I got....
Old Jan 9, 2004 | 08:01 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Re: Fuel System
I would just start at the beginning with a DVOM and a shop manual. Check for good grounds, check for good connections, check the sensors to make sure they are operating properly. It really can be a cat and mouse game sometimes, but you will learn so much about engines and drivablity is you take it from a systematic approach and are careful. Good luck...
Old Jan 12, 2004 | 08:51 AM
Engine: TPI 350
Alright, thanks for your help I'm going to get right on it as soon I get the time.
Old Jan 15, 2004 | 07:20 AM
Engine: TPI 350
Would my problems might be caused by a bad vaccum hose. I found my it was completly split. Im hoping that was it. I got a new tube and everything seems fine for now.
Old Jan 15, 2004 | 08:45 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Really bad vacuum leaks can cause engines to stall and many other various drivability problems. So, if it works now, then I say you found your culprit...
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
