Does the Superram plenium clear the wiper motor?
Old Jan 18, 2004 | 09:30 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have a 1988 Firebird that I will be putting a Superram on and the plenium to wiper motor clearance looks like it is going to be a problem. Does anyone know if the wiper motor will clear the plenium?
Thanks for the help.
Old Jan 18, 2004 | 09:38 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
yes,with plenty room to spare.
Old Jan 18, 2004 | 09:44 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
My SR is VERY tight up against the wiper motor. Any tighter and I'd have to remove the motor. I have poly motor mounts though too.
Old Jan 18, 2004 | 10:19 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
On my 89 Camaro: I had to remove the rubber motor mounts on the wiper motor. I had also gotten new motor mounts for the block from the parts store and I still had to cut into the flat 5 or 6 pin connector that plugs in the motor.
Old Jan 19, 2004 | 12:30 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I also had to remove the rubber mounts
/N.
Old Jan 19, 2004 | 09:45 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
My SR is up against the wiper motor, also, but barely. I ground a bit off of the back corner of the plenum.
Old Jan 20, 2004 | 04:01 AM
Z_Ghost's Avatar
I had to do the same thing, funny the plenum is about .780 thick back there so I used a die grinder and took ground off about .400 .
Frozer!!!
Jan 19, 2024 04:55 PM
Randomtask2
Aug 26, 2015 03:34 PM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
slade5612
Aug 11, 2015 07:19 PM
NBrehm
Aug 5, 2015 07:57 PM
