what is the power range for tpi
Car: 87 plane jane with gfx
Engine: 350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
Transmission: super t-10 or t-5
Axle/Gears: auburn with 3.42 stock axles
i have been told that a tpi system stops making power a 4000-4500 rpm when its stock is that true and will it produce power to higher rpms when mods are done to the motor and not the injection or is that just killing the motors potenial
yeah it dies around there, thats why i think i lose e.t time in the 1/4 mile because my tranny shifts like around 5,500 on the 2nd to drive shift.
u can feel the engine just reving and not pulling anymore. just run out of hp and its limits.
so when i drag race shifting at 5000 rpm is good for my tpi or can i pull higher because i did a sipmle port and polish job with a dremel tool to the exhaust ports and just polished the intake ports but i dont know if that with the headers and the flat tops and cam that i put in it would let it pull higher or just more at the normal rpm range
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
the real tpi powerband = 4200 rpms - 4600 rpms..
everything else is just cookie dough
and just for the record... the L03 stock camshaft powerband is Idle - just off idle
Iroc8t8
May 4, 2026 08:09 PM
theshackle
Sep 17, 2020 08:26 AM
Sanjay
Aug 12, 2015 03:41 PM
