massair burnoff code 36
Old Jan 23, 2004 | 06:20 AM
blackroc68's Avatar
I have changed the mass air burnoff relay/mass air power relay
/mass air sensor.i still get code 36.i also changed wirering connecter. any ideas.Do you think it could be my chip? also changed ecm. any ideas?
Old Jan 24, 2004 | 12:55 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
bad oil pressure switch? the oil pressure switch initiate the burn off when the oil pressure drops......
Make sure the MAF gets 12v within 20s after you shut down the engine at terminal "d" i think.............
Do a search about the subject alots of info.
Old Jan 24, 2004 | 09:33 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you disconnect the battery and clear the codes from the computer memory? The codes will continue to pop until this has been done. If you have already done this and they continue to pop up, then yes, you have a problem. Check for a loose or bad connection at the MAF sensor relay and the MAF burn-off relay.
The Trickster!!!!!!!!!!!!
Old Jan 24, 2004 | 02:12 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Also check the female pins inside the MAF sensor connector. They can slide up in the connector and not make good contact with the MAF sensor male pins.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
