LT1 Heads
Old Feb 3, 2004 | 09:28 PM
CScheip92's Avatar
Car: 1992 Camaro RS
Engine: LO3
LT1 Heads
I bought a set of LT1 Aluminum heads and am planning on following tpi_roc's instructions in his thread. Questions:
1. With the cooling ports blocked, will the heads not overheat?
2. I'll be using an LT1 intake, so what will I not have to have done to the intake?
3. This will be in my daily driver, any problems there?
4. Does an LT1 intake require a specific ECM or will my 165 do?
5. Any other problems anyone forsees?
Old Feb 4, 2004 | 09:05 PM
CScheip92's Avatar
Car: 1992 Camaro RS
Engine: LO3
tpi_roc? John?
TTT
Old Feb 4, 2004 | 09:38 PM
85TransAm406's Avatar
Car: 1985 Trans Am
1) the coolant ports aren't blocked, the stock big coolant holes are plugged, but a new smaller round hold is drilled using a standard small block head gasket as a template.
2) you will only need the distributor mod done, and EGR block off plates.
3)I wouldn't forsee any problems. Still workin on my intake conversion though. John has done almost 100 intake conversions for people, and has started a feedback page on his site. Read some of the stuff there to maybe get an idea of how well the people with converted intakes are running.
4)Stock ecm will do, as it will hook up to your injectors, IAC, and TPS sensors. just extend the coolant temp sender lines, and relocate your IAT sensor.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
