What is this cable for?
Old Feb 7, 2004 | 01:30 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
It came with my TPI wiring harness and i don't know what it is. I'm guessing something having to do with the cruise control. Thanks.
Old Feb 7, 2004 | 01:31 PM
pwdbychevy's Avatar
pwdbychevy's Avatar
Old Feb 7, 2004 | 08:48 PM
pwdbychevy's Avatar
ttt
Old Feb 8, 2004 | 03:08 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
That looks like smog pump stuff to me but hard to tell.
Old Feb 9, 2004 | 01:05 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
i thought it was for the AC
Old Feb 9, 2004 | 06:20 AM
pwdbychevy's Avatar
Firebird owners might be able to identify it because it came from 1991 Firebird with 350 TPI. Any firebird owners want to take a crack at it?
Old Feb 9, 2004 | 12:40 PM
llvll4l2c91350's Avatar
i've looked on both my 89 and 91 formulas and dont see anything that looks like that. i'm also curious to know where it comes from. the cruise control in the 89 has something similar but with a totally different plug.
Old Feb 10, 2004 | 05:56 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Correct me if I am wrong but the connectors appear to be off of a Ford vehicle. Just letting you know.
Old Feb 10, 2004 | 06:55 PM
pwdbychevy's Avatar
that's a possibility. it came with my Tpi wiring harness and thought it was hood light assembly because of the vaccuum line or washer fluid hose.
Old Feb 11, 2004 | 03:53 PM
MrDano's Avatar
Car: 1987 Monte Carlo LS
Engine: 357 TPI, LT4 hotcam
cruise control maybe
Old Feb 16, 2004 | 09:30 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Did you ever findout what it is?
I've had my smog pump off many times, and that's definitely not smog related.
The closest thing I have under my hood to that is the cruise control. My connectors are different, and mine has a separate ground wire coming from the harness that I don't see on yours. But other than that, from the length of your wiring and hose, and the way they're bound together, it looks like my cruise control.
So I'd say you're right.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
