Accel inj. vs ford inj.
Old Feb 12, 2004 | 09:33 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I talked to ed wright and he was telling me that they don't even bother w/ the accel inj. b/c they're crap. I know I've seen a bunch of different people on here that have run the accels w/ good luck. I understand that the fords are rated at a different psi than the accels, but I just bought 30# not knowing. Will it hurt me that much to use the accels? Or am I better off eating $230 and buying another set from ford?
Old Feb 12, 2004 | 11:16 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
I've had the 24# Accels since about 140,000 miles with no mechanical or performance problems. I did have problems with leaking o-rings after install, due to small yellow plastic shavings from the injector body stuck behind the o-rings. Luckily, I pressurized the system after I installed the fuel rails to check for leaks before completing the job. I'd remove all the o-rings and check for crap in the grooves, others have posted about the same in the past.
Old Feb 12, 2004 | 12:11 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I have had 30# Accell injectors for over 2 years. No problems at all. I did not even have the o-ring problem that was mentioned above. A simple install and I have forgotten about them, if you know what I mean...
Old Feb 12, 2004 | 01:21 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I have been running the Accel 30# injectors for about three years. Although I have only put about 300 miles on the car in that time(but they have been hard miles). They fit good and work well.
Old Feb 12, 2004 | 07:07 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
My 2 cents worth is everything ive ever used from accel has been garbage and their injectors are finally coming down to real world price where everyone elses have been. I still think the Ford Inj are a better design and u can get them anywhere at moments notice and up to 30# are 200-220$ ....
Its all i use now and ive never loked back
LAter
Jeremy
Old Feb 12, 2004 | 10:04 PM
blackroc68's Avatar
accel injectors
accel injectors suck. Dont waste your money!!! only used for 4 months and 1 shorted out filling my brand new 383 with fuel.only hope it didnt cause long term engine damage. just giving you my experiance with them.save yourself some heartache.
Old Feb 13, 2004 | 12:30 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I've always used the SVO Ford injectors and never had any reason to switch to anything else. They are the best buy for the money as far as a new injector goes. Ford's fuel injection stuff is about the best there is. They've done it right since the beginning, unlike the General.
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
e3pres
Sep 9, 2015 01:51 PM
