how much hp do ya think?
Old Feb 19, 2004 | 10:20 PM
noah98ss's Avatar
Car: 98 ss & 91rs
Engine: ls1& 5.7 tpi
Transmission: 6 spd& 700r4
5.7 TPI
58mm TB
COMP CAMS .510/.510,220/230 @.50 ROLLER
WORLD PROD,SPORTSMAN 2 HEADS 2.02X1.6
1.6 ROLLER ROCKERS
PETE JACKSON GEAR DRIVE,
TES HEADERS
FLOWMASTER 3" CAT-BACK
UNFORTIONATLY STOCK PLENUM,RUNNERS AND BASE
HOW ABOUT THE MINIRAM OR ANYTHING OTHER THAN STOCK TPI?HOW MUCH INCREASE
ALSO HAS ACUSTOM CHIP FROM HOWELL ENG
ANY IDEAS WOULD HELP
OH YEA MARCH UNDERDRIVE PULLEYS BILLET
AND THE ENGINE IS BORED .030,TRW FORGED PISTON
AND FULL INTERAL BALANCE
THANKS
Old Feb 19, 2004 | 10:38 PM
5SIZ's Avatar
Car: 1987 IROC-Z
knowone is going to give ya an accurate answer.
w/ stock tpi setup.
300-400 hp. HUGE bottle neck.
Old Feb 19, 2004 | 10:57 PM
noah98ss's Avatar
Car: 98 ss & 91rs
YEAH I CAN KINDA FIGURE THAT THE TPI DOES SUCK I HAVE 24LB INJECTORS ALSO ,THE THING PULLS PRETTY GOOD UNTIL ABOUT 4500 RPM THEN FALLS ON IT FACE ,I WAS JUST LOOKIN FOR A BALLPARK HOW ABOUT IF I HAD A DIFFRENT SETUP? ANY RECOMMENDATIONS FOR MY SET UP?
Old Feb 19, 2004 | 11:56 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
The Stealth Ram setup would work great for you. Or the TPIs Mini Ram setup. Those will help get rid of that bottle neck you have there.
Old Feb 20, 2004 | 12:56 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Your stock intake is choking it out. Its only rated for 4500 rpms. I agree with thirdgenfire. As far as your hp goes all you'll get are guesses, just like 5SIZ said.
Old Feb 20, 2004 | 04:47 PM
noah98ss's Avatar
Car: 98 ss & 91rs
THANKS FOR THE REPLIES GUYS INEED TO TOSS THE INTAKE,DOENT MATCH ANYTHING ELSE I HAVE THANKS AGAIN ,JUST TO LET YOU KNOW ,THE CAR IA A91 RS HAD THE 305 TBI,I JUST WANTED TO HAVE A TPI SO I BOUGHT ONE NOT KNOWING THAT IT DIDNT FLOW FOR **** SPECIALY WITH THE HEADS AND CAM I WENT WITH ,IT STILL FASTER THAN IT WAS THATS FOR SURE BUT I WILL CHANGE THE INTAKE ASAP,MAYBE THE TPIS MINI RAMTHAT SHOULD WAKE IT UP THANKS AGAIN
