305 Stealthram Fuel Pressure for 24lb Inj??
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
350 Stealthram Fuel Pressure for 24lb Inj??
I have finally finished getting my car running and I have been to the Race track two times now. The first time I went, I ran a 13.02@104. Yesterday, I ran 12.85@104. Since the first run, I haven't adjusted or messed with the fuel pressure. It is currently at 44PSI and I am running 24lb SVO injectors on my stealthram 350. The car seems to "fart" under part throttle but then runs better as the pedal gets closer to the firewall.
Anyways, here is my setup and I would like to see if anyone would have the best fuel pressure to set the car up to run a bit stronger.
-1990 350 Iroc-Z (Speed Density)
-Stock 350 block - only high volume oil pump and double roller timing chain.
-Factory Stock chip.
-ZZ4 CAM
-ZZ4 Heads, slightly ported and gasket matched.
-1.52 Comp Cams Roller-tip rocker arms
-Running ~12 Degrees advance
-44 PSI fuel pressure
-24lb SVO injectors
-Holley Stealthram Injection
-Stock 48MM Throttle body.
Sorry for the long info. Hope someone can help.
Thanks,
Pablo.
-ZZ4 CAM
-24lb SVO injectors
Thanks,
Pablo.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: 350 Stealthram Fuel Pressure for 24lb Inj??
-ZZ4 CAM
-24lb SVO injectors
Thanks,
Pablo.
-ZZ4 CAM
-24lb SVO injectors
Thanks,
Pablo.
PS: I sent you a PM before I noticed this thread.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
