can a tpi support..........
Old Mar 1, 2004 | 08:36 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
can a tpi INTAKE support 500hp with larger injectors and SLP runners and a holley TB? It will be a speed density itnake.
Old Mar 1, 2004 | 09:00 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You need a lot I mean A LOT of work done to it to put out that much horse power. To the TPI and engine. It is attainable to reach 500 ft./lb torque without much trouble though. SLPs are not the best choice for runners if that was the plan either. You are probably looking at an entire aftermarket set-up. HSR, minni-ram, SR, or LT1. Of course you could super/turbocharge.
Old Mar 3, 2004 | 12:00 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
No, I don't believe so.
Jake
Old Mar 3, 2004 | 01:00 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you are talking about long tube runners, then I think it would be very difficult. Although, the FIRST long tube runner unit looks as tho it breaths enough for 500RWHP. The most I think you'd be able to get with ported plenum, ported SLP runners, and ported aftermarket base would be around 400RWHP. The FIRST stuff is very big compared to everything else.
If you are talking about maybe getting one of the high rpm intakes (hsr, lt1, miniram, suprram) then I think it can absolutley support 500RWHP.
Tuning is an assumption.
Old Mar 3, 2004 | 01:12 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: can a tpi support..........
You need to change intakes. I had tpi and swapped to HSR because the ported tpi intake I had would only put out 4500rpms max. After that it would flat line. You could buy an HSR setup for 500 dollars (intake, box and rails). SLP runners are around 250 (wont need them for this). And you could use a stock TB for the HSR and save money there as well. The tpi intake will support 500hp but you will be happier going a different route.
Old Mar 3, 2004 | 12:13 PM
89305RS's Avatar
cool thanks for the input guys. i might do that hsr intake.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
