IAC adjustment, what tool?
Old Mar 2, 2004 | 11:03 AM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
I'm trying to do the iac adjustment procedure and I'm having a hell of a time finding the right tool. What do you guys use?
I know its a t20 torx, but there's isn't much room there. The throttle bracket is right behind the screw so I can't get a screwdriver type t20 in there. To top it off, I have the Edelbrock strut tower brace and that happens to cross right in between the screw and the throttle bracket.
Wish I had a picture. What do you guys recommend?
Thanks.
Old Mar 2, 2004 | 12:40 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: IAC adjustment, what tool?
Thanks.
I am not familiar with GTA's but on my Camaro there is no adjustment for the IAC. Its a sensor with a connector and it is screwed into the underside of the throttle body. You adjust it by jumping the ALDL etc. Do you mean the TPS?
Old Mar 2, 2004 | 12:42 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
I mean the idle speed adjustment.
Doh!
Old Mar 2, 2004 | 12:43 PM
Morley's Avatar
He means the minimum air adjustment screw.
Use a T20 bit with either a 1/4" wrench or dogbone, may have to remove the STB to do the adjustment.
Old Mar 3, 2004 | 12:58 AM
Doh!
Thats fine. Maybe I was confused. Do what Morley suggested.
Old Mar 3, 2004 | 12:53 PM
chevyboy07 91's Avatar
i just pull the throttle bracket there on the plenum..makes life EZ. DONT allow those loose ends to touch the alternator "hot" source (i dont have the cover LOL)
db057
Jan 10, 2020 08:55 PM
Mark_ZZ3
May 24, 2018 01:02 PM
92projectcamaro
Dec 8, 2015 12:25 AM
greenyone
Sep 8, 2015 08:41 PM
