high reving idle probs
Old Mar 1, 2004 | 12:43 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
sometimes my car will rev up and down and sometimes die. if its doing it and i get on it a little bit it clears up. it get real irritating what can it be. btw i have a new iac and tps
Old Mar 7, 2004 | 08:36 PM
demon138's Avatar
now its impossible to drive its so bad and its shooting code 33 which i dont have on my 89 computer. reallly really need help!!! please
Old Mar 7, 2004 | 11:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It sounds like your MAF sensor has hit the south 40 for good. You can take it off and spray it with some electric contact cleaner and see if that helps it. If it doesn't, then it is time to get a new one. I would also check the MAF sensor relay and the MAF burn-off relay. You can test to see if it is the MAF sensor by disconnecting it and starting the engine. If the engine runs smoothly like it should, then the MAF sensor is your problem.
Old Mar 8, 2004 | 01:34 PM
demon138's Avatar
but ive changed all those about a year ago and also this only happens sometimes
Old Mar 8, 2004 | 03:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That doesn't mean that they are still good. You should still check by disconnecting the MAF sensor and see if the engine smooths out. Check all the wiring for these items.
Code 33 = MAF SENSOR circuit (GM/SEC HIGH)
Old Mar 9, 2004 | 12:28 AM
demon138's Avatar
in my chiltons code 33 is map sensor and 34 is maf sensor or am i wrong?(not being sarcastic just curious)
Old Mar 9, 2004 | 12:46 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay Demon138,
Code 34 is the opposite of code 33, while code 33 = MAF sensor circuit (GM/SEC HIGH). Code 34 = MAF sensor circuit (GM/SEC LOW). No, I don't take you as being sarcastic and I can understand you being curious. There are just two sides to the codes posted here, usually if there are two codes posted for the same system. The odd number code will be for the high side and the even number will be for the low side. Hope this gives you a better understanding of the trouble codes. You should also remember that Chilton's deals with all 3rd gens from 1982 - 1992. The TBI models in 1989 used the MAP sensor and starting in 1990, the TPI's also used the MAP. Your car, being a TPI, used a MAF sensor unless you switched over to a MAP sensor system.
84z96L31vortec
Aug 20, 2017 12:16 AM
billybob6110
Sep 24, 2016 09:50 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
