Do i have dual CATS?
Car: 1989 IROC-Z
Transmission: 4 speed auto
hi, i just won the bid for a 1989 iroc camaro on ebay. it is equiped with the 350 motor and the stock trans. i was wondering how i can tell if i have the dual catalitic converters (sorry for spelling i am in a hurry lol). i dont have the car yet, because i couldnt get it this weekend. is there anyway from the vin, will it tell there. thanks for your help, i am cant wait to be a proud camaro owner!!!!! albert III
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If N10 is in the RPO codes, it should have them...
Car: 1989 IROC-Z
thanks!
hey thanks for the help and quick responses. i have yet to see a picture of the rpo code, so i guess thats the easiest way, so when i get a pic of that, i could find out then. thanks again albert III
Car: 89 IROC
Engine: 5.7 TPI
Transmission: 700R4 w/ transgo kit
Originally posted by llvll4l2c91350
pretty sure all the 350s starting in 89 got the dual cat setup.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If its a single cat, then you're cursed with the dreaded 2.77 9-bolt rear end.
Does it have t-tops? If so, then you know its a single cat car, as well.
Car: 1989 IROC-Z
yes it does have t-tops, so that means it has the single cat?
albert III
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I've seen plenty of ttop cars with dual cats.
Don't worry about the 9bolt. It's a good rear, but the 2.77's will suck. A good majority of the L98 cars came with 10 bolts anyway, so don't worry about it until you get the car and find out what you've got.
Car: 89 Iroc
Engine: 5.7 liter (L98)
Transmission: TCI 700r4
I have a 89 iroc that has t-tops and had a 2.77 rear and came with single cats. Swapped the rear for $100 to a 3.27 9 bolt posi.
There itsn't that much a difference at only 10hp. between single and duel cats.
LT1Formula
Oct 8, 2015 08:34 PM
