holley stealth ram question
Old Mar 4, 2004 | 01:27 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
whats my car going to do when i delete the cold start injector and the egr when i do the hsr swap?
Old Mar 4, 2004 | 02:14 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
You don't have to have CSI, your car will just have trouble starting cold. The easy fix is to run an ARAP or other '89 bin, no other changes needed just the chip. There's no way to run EGR with the stealth ram unless you want to run a custom one-off setup. A bigger cam with a little overlap will do the same thing as EGR anyway.
Old Mar 5, 2004 | 11:33 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
just like roostmeyer said. it's not easy to start in the cold months. here shortly i'm going to try an 89 .bin again. kept getting a MAF error the last time i did.
Old Mar 6, 2004 | 09:51 AM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Ok which would be better getting a Chip burnt for the car or getting just an 89?
I have a 87 350 & we just installed the HSR.
Old Mar 7, 2004 | 11:50 AM
mrr23's Avatar
Engine: 360 HSR
the 89 would be better. make it easier to start when cold. i've been using the 87.
Old Mar 7, 2004 | 12:57 PM
OMINOUS_87's Avatar
Its always best to burn your own chips.
You can tune idle, cold start, fans, TCC, EGR, highway mode, etc... all to your own preference over time until things are perfect.
Of course you can always dial in performance mods for max output as you go.
I run ARAP on my 87 and have never got any codes out of it after the conversion, no probs at all.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
