k&n filters or SLP cold air intake
Old Mar 4, 2004 | 03:50 PM
iroc88ohio's Avatar
Car: 88 iroc
Engine: 5.7
what would you go with? replacing the stock filters or the cold air setup? for the money which is better?
Old Mar 4, 2004 | 03:58 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I'd say CAI is better, but all I'm running now is K&N.
Old Mar 4, 2004 | 07:12 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
slp cai is a waste of money for a camaro. i read somewhere on here that the stock air intake doesnt become restrictive until you are over 300 horsepower. i would just go with the k&n filters and cut the baffles off the bottom of the filter trays.
Old Mar 4, 2004 | 07:23 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you have the stock dual snorkel intake then KEEP IT. It is a great intake once you cut off airbox bottoms. Save your money on the SLP CAI and get some headers.
Old Mar 5, 2004 | 07:23 AM
iroc88ohio's Avatar
Car: 88 iroc
Engine: 5.7
i have the dual snorkal intake on my car, how much of the bottom do i cut out the whole thing or what?
thanks for the info!
Old Mar 5, 2004 | 02:52 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
When you lift the LID you can see the FILTERS sitting in the FILTER HOUSING. Take that off and flip it over - it is pretty obvious, you will see. You just take a dremel, or a hacksaw, or whatever and cut the bottoms off so the filters are sucking thru an open window. Right under the lip that the filter sits on is perfect.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
