size of injectors
Old Mar 7, 2004 | 11:15 PM
zyal8er's Avatar
Car: 1991 Camaro z-28
Engine: 5.7 350 TPI
size of injectors
I am looking to buy accell injectors for my 5.7 tpi. How do you know or find out what size I should be using. I had thought that 24# was stock but I am not sure. I would look at the ones in the car, but of course the car is still in storage due to snow.
Please help so I can use my Z this summer!
Old Mar 8, 2004 | 12:26 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The stock injectors for the 5.7L are 22#.
Old Mar 8, 2004 | 05:46 AM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
i ordered a set from www.fiveomotorsport.com they're ford parts but they're 22 lbs at 43.5 psi. Only 200 bucks including shipping and they work great.
Old Mar 8, 2004 | 07:50 AM
MdFormula350's Avatar
http://www.slponline.com/view_produc...RTNUMBER=23051
might want to check out these.
Old Mar 8, 2004 | 01:03 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
The formula to determine injector size is:
lbs/hr x 16 = horse power output
Trickster is correct. If you do any future mods and increase hp you will need this formula to determine what size injectors to upgrade to.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
