SD harness to stand alone...HOW??
Old Mar 9, 2004 | 03:40 PM
smokingss's Avatar
Ok, ill make this as quick as possible. My plans for a 350 TPI 5 speed swap into my 88 iroc convert has gone the way of the dinosaurs, BUT Ive decided to swap it into my 87 Monte Carlo SS. I have the TPI unit, 730 ecm, (getting 350 memcal), VSS, Stock 92 Camaro TPI Speed density 5 spd engine wiring harness. I need to know how I would rewire the stock SD harness to work as a stand alone system. I know Painless wiring sells a harness for 300 so I may just do that, but I figure since I sorta have one already, I should give it a shot. Anyone have a list of wire colors and functions for the firewall connector? I figure I could work off that. The only additional thing I think id have to do is get a chip burned to run without VATS and emssions junk. any help would be appreciated.
oh and yes, i know i have to mess around with fuel lines and pump. Motor will be stock except for full exhaust and k&N....
Old Mar 9, 2004 | 08:40 PM
TPI78TA's Avatar
Car: 1978 Trans Am
Engine: TPI 350
I recently pulled the TPI out of an '86 T/A. I don't know if there are any differences between '86 and '88. I swapped it into a '78 T/A. The system is pretty much a stand alone system. I have yet to go through the part of the harness that goes into the interior, but I'm assuming that part is for the gauges and power. I can get the wire colors when I get home in the morning, and get a better description of what the connectors do.
Old Mar 10, 2004 | 09:10 PM
rockind78's Avatar
http://www.eecis.udel.edu/~davis/z28...730v8tpi-1.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-2.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-3.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-4.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-5.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-6.jpg
http://www.eecis.udel.edu/~davis/z28...730v8tpi-7.jpg
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old Mar 11, 2004 | 05:26 PM
smokingss's Avatar
All those wiring diagrams mean nothing to me, They are for the ECM connectors. I need the connector at the firewall on the driver side, right before where it goes to the fuse block. I have the SD harness and ecm already, thats not the problem. My task is to make the SD harness function in a 87 monte carlo, i need to know which wires in the firewall connector are Batt, ground, acc, etc.. Once i know that i can wire it up to work as a stand alone unit.
Old Mar 11, 2004 | 09:11 PM
rockind78's Avatar
If I am understanding you correctly, the firewall connector is sort of "scrambling" your ability to know which wires are which. I had this same problem when I modded my MAF harness I used a continuity tester. They are a couple bucks at the most at your local hardware store. I notched a very small portion out of the insulation on the wire I was trying to follow, and then did the same on the other side. If it lit up, I had my wire. To cover up the notches, I bought some "brush on" electrical tape.....intersting stuff. Maybe there is a better way?
Old Mar 14, 2004 | 09:36 AM
onetontj's Avatar
I put a 92 TPI motor in my Jeep which had no existing wiring...I used the painless kit for $300 and it literally took me 15 minutes to wire the motor. It was such a breeze, very cool product and very easy to use. Sounds like it is just what you need since you ditched the 2nd gen.
CJ
Old Mar 19, 2004 | 03:50 PM
smokingss's Avatar
ok, painless wiring harness it is, thanks CJ, i never used any of their harnesses so i didnt know how easy it'd be, (i once bought their harness for an lt1 but i had a 96 lt1 and they only make 93-95 lt1 harnesses, go figure) I'll order the SD tpi harness tonight. I have the motor on a stand now putting the TPI system on it, and hopefully itll be ready to go in the car next weekend.
Old Mar 19, 2004 | 04:27 PM
JerseyIrocZ's Avatar
Car: 89 Iroc
Engine: 5.7 liter (L98)
Transmission: TCI 700r4
talk to the guys at montecarloss.com a few of them have done this they will tell you just what you need to do.
Old Apr 28, 2015 | 11:50 PM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
Re: SD harness to stand alone...HOW??
Those diagrams were useful!
Old Apr 29, 2015 | 04:13 AM
tmoble's Avatar
wow, eleven years worth of water under the bridge but somebody still getting good out of this old thread.
gixxer92
Apr 12, 2022 12:09 AM
2012sergen11
Oct 13, 2015 07:38 PM
crystal383
Interior Parts Wanted
Sep 22, 2015 01:20 PM
Camaroguy2
Sep 22, 2015 08:22 AM
ericjon262
Sep 11, 2015 06:07 PM
