difference between 87 and post 87 L98's
Old Mar 13, 2004 | 09:40 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
is the only difference the Serpentine setup? if no what else is different, other than cam, etc... not performance wise is basically what i mean. i know that the cams changed over the years. also what is the problem with the non serp setup on the 87's? i ask because i am looking at a 87 Formula 350 and haven't decided if i want to buy it or not.
Old Mar 14, 2004 | 01:33 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Well all I can remember off the top of my head is starting in 89 they got revised "multec" injectors and removed the cold start injector, then in 90 they got new lighter pistons (and a 5hp increase) and I think 90's also went to a map system over the maf setup. Also like you already mentioned the cams changed also.
If I can think of anything else I'll edit this post with it.
If the price is right, I'd be happy with a 87
Old Mar 14, 2004 | 06:27 AM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
yeah, well i haven't got to give test drive the car, it's in pretty good looking condition. but the real test will come when i test drive it. thanks for the info.
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
