Injector size question
Old Mar 14, 2004 | 12:59 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Hello, my 89 GTA resto is coming along and the engine block is put together. Block bored .30 over, machined crank, new rods, pistons, blah-blah. I put in a mild cam and the exhaust will be slp headers and system. Anyway what size injectors would be good with this set up... Thanks.
Old Mar 14, 2004 | 07:05 PM
onebinky's Avatar
what are you doing for heads and intake setup? If your staying stock on both, than I'd think the stock 19 lb (305) or 22 lb (350) should be sufficient for you
Good luck
Old Mar 14, 2004 | 07:36 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
If you're set on buying new injectors the SVO 24lbs are cheap and will work great with PROM tuning.....just a simple FBC change is all thats needed...
Old Mar 15, 2004 | 06:57 PM
Notplayn's Avatar
thanks for the replys.. I am using the stock intake but I have another question- I am not sure if the injectors that I have came out of a 305 or 350 (long story). I have them on my work bench and I have heard people reference colors. They appear to have a yellow band around them.
Old Mar 15, 2004 | 09:28 PM
onebinky's Avatar
I dunno, maybe try a search on all the past posts. It's gotta be in there somewhere
Good luck
Old Mar 16, 2004 | 07:33 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Get any 24#/hr injector for our cars. They will work well with the stock ECM. But also, get an adjustable fuel pressure regulator (AFPR) so that you can tune in the best AFR for WOT running.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
