Fuel injectors
Old Mar 15, 2004 | 10:33 PM
Canuck 88' T/A's Avatar
Fuel injectors
Hey, does anyone know what size injectors (lbs) that the 1988 305 TPI and 350 TPI ran stock? I need to know what injectors to plant in my new 383 stroker. Appreciate any help!
Old Mar 16, 2004 | 12:56 AM
viperwsu's Avatar
Car: 91 Camaro RS
Should be 19 and 22 lb/h respectively. I would think that the 383 would be happy with 24s, but ChevyThunder says that 22s can be pushed high enough with increased fuel pressure. It'd be tight, but possible.
The stock injector size is an easy question to answer, I found it in less than 15 seconds in the FAQ. Try searching for yourself before posting, most questions have been answered at least 3 times on this board.
Old Mar 16, 2004 | 07:31 PM
Thanks for your help and advice! I will check the boards more frequently!
Old Mar 16, 2004 | 07:35 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
For a 383, buy 24#/hr injectors and install an AFPR.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
