BBK 52mm Airfoil?
Car: 1987 Camaro IROC-Z
Engine: 5.7L
BBK 52mm Airfoil?
Didn't know where to post this question, so hopefully someone can answer me. Im wondering if there is a throttle body airfoil that will work with the BBK 52mm throttle body. The Hypertech unit from my stock throttle body won't work, but is there any others that will? Any help would be great. Thanks.
Engine: 5.7L
I know that the BBK and other aftermarket units come with an "airfoil" kind of built in already, but I was wondering if there is something else to help smooth the air out a bit more. Thanks.
Car: 1990 IROC-Z
Engine: 350 L98
your tb should be fine the way it is. dont even bother trying to smooth the air out anymore, it's designed to get as much air as it can get for a 52 mm tb
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I agree, no airfoil should be necessary or beneficial on either the Holley or the BBK throttle bodies.
Fred SS
10-12-2015 11:27 AM
IROCNParts
09-24-2015 10:50 AM
Navy8125
08-22-2015 07:13 PM
