Run out of mods to do?
Old Mar 16, 2004 | 07:13 PM
mhaskell's Avatar
So I'm looking for the next bolt on mod that is going to make a difference. THe car is a 92 ws-6 L-98, so far.
-K&N direct intake
-airfoil
-making large tube runners, ported plenum and base
-1.6 roller rockers
-edlebrock headers
-3 inch high flow cat
-electric cutout
-3 inch hooker cat back
-LCA's,panhard bar and poly bushings
-T-56
-3.42's
B&M ripper,LT4 clutch
all new ignition, filters etc..
So the next step is heads or cam. Since I drive the car everyday I can't have hte car down longer than that (yes the T-56 swap was a one night job). I dont want to go FI or Nitrous, and don't have a ton of money. I prefer to make my own stuff, like the runners and electric cutout.
So whats next? I don't care about handling that much, i never push the car handling wise, just drag race it. I think nittos 555r's are the next thing to buy?
Old Mar 16, 2004 | 08:30 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
subframe connectors, lower control arms, and a panhard bar will help launches a lot.
Old Mar 16, 2004 | 09:21 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
He's got two of those.
Subframes should have been installed long ago. Nitto 555Rs are a great tire.
Whats a K&N direct intake? If it is a throttle body mounted filter then make a real cold air intake. A TB mounted filter will suck in air about 40-50 degrees hotter than a functional cold air intake.
Get a good tune. That's a bolt on too - and at this point of modification with the stock programming you are losing anywhere from 25 -40 rwhp.
Old Mar 17, 2004 | 07:22 AM
mhaskell's Avatar
I have SFC's forgot to mention. Also I have the GTA hood and the front vents are cut out from the bottom. It dumps outside air right on the filter.
I guess a tune is next, I really need tires I trap at 101 right now but am barely in the 13's
Old Mar 17, 2004 | 09:23 AM
MdFormula350's Avatar
yeah i definitely think some suspension mods are in order.
Old Mar 17, 2004 | 11:00 AM
mhaskell's Avatar
I looked into the lack of traction, When I swapped in the T-56 i used a 4th gen torque arm mount, i think this threw off the pinion angle. I am looking to see if a third gen t-5 mount will be better. Does anybody have a pinion angle gauge I could use?
Old Mar 17, 2004 | 11:03 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
weight reduction
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
NWAsonoma
Aug 18, 2015 05:45 PM
matthew911
Aug 12, 2015 09:38 AM
