Installing a cam, have a few questions.
Old Mar 17, 2004 | 12:59 PM
bonz's Avatar
Car: 89 GTA
I want more power so I figured I would go with a different cam. The one I found is Crane PowerMax it has 204/214 duration and .423"/.446" lift. I heard that you dont want more than .430 lift so is that going to be to much. I want a cam that is as big or a little bigger than the cam in the 305 manuals and the other cams that ive found are a little smaller. Also will I have to worry about the computer not working right with this cam. THANKS
1989 Trans am 305 TPI Automatic, 2.73 rear, K&N filter, underdrive pulleys, air foil, tb bypass, low restriction exhaust
Old Mar 17, 2004 | 01:44 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Personally, I think the cam is too small considering all the trouble you have to go through to replace the cam. The computer shouldn't have a problem. That cam isn't much different than the stock cam that cam in my 305. But since you don't plan on doing the heads that cam should work fine. I am changing my cam and from what I have heard the stock heads will be a big restriction so I plan on doing them at the same time as the cam. I'm using either a 212/218 cam or 218/224 CompCam XE.
84z96L31vortec
Aug 20, 2017 12:16 AM
anesthes
Mar 10, 2016 10:35 PM
69 Six Pack
Oct 5, 2015 07:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
