Anyone ever clean there throttle bodies?
Old Mar 16, 2004 | 07:00 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I was jsut woundering, because i usually take some carb cleaner/intake cleaner and spray it in the throttle body when the car is off and the throttle open and take a tooth brush and scrub. Well, ever since then, the car has not run right. Any one know that i did wrong?
Old Mar 16, 2004 | 09:25 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Carb cleaner is for carbs. Throttle body cleaner is for throttle bodies. Carb cleaner does something to fuel injected cars... I think it can mess with the O2 sensor amongst other things.
Old Mar 17, 2004 | 09:41 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I used carb cleaner on mine before, and no problems. Its basically the same thing as throttle body cleaner...
Old Mar 17, 2004 | 09:53 AM
383 rocket bird's Avatar
What is much better than cleaning that way is to take it of the car, fully disssemble it, and then reassemble/install withg new gaskets, does wonders for idle quality and throttle respnose if you have a really gunked up tb. -John
Old Mar 17, 2004 | 10:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I did it the way rocket bird is talking about, but I went to extremes. I sanded and polished the throttle blades to a mirror finish. Knifeedged the blades, and then powdercoated with 96% gloss clear. Looks really good. Wish I could post a picture.
Old Mar 17, 2004 | 02:47 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Me too.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
