Tunning The computer 305TPI
I've never messed with the computer on the TPI and have no ideal what software/hardware I would need in order to tune my 1991 Z28 305 TPI or if it even needs it.
Its got a mild crane cam, bored. 30 over, headers, MSD ignition, 2500 stall. All this has been done to the motor and the computer is stock. It seems as if its running to rich cause you can smell gas real bad kinda like its fludded or loading up. I would assume the computer would have to be tuned since all thats been done to it and its still set to stock 305. Someone told me that you have to manauly program or have someone program the computer for the 91 camaro's. I havent been able to find someone in the Springfield, Missouri area that can do it.
What all would I need in order to do it myself? I've got the laptop. I'm going to check the timing on the car I thought maybe that might be off. It just seems like the car doesnt run like it should.
Or I would pay someone to do this if they know how to and are close to Springfield, Missouri?
Dustin
Dustin
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You may want to browse around the DIY Prom board. There is a sticky at the top that does a good job of explaining what you need.
ok, thanks
Trying to post video of motor, just to see if it works
http://csice.tripod.com/engine_2.mov
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
