1.6 roller rockers
Old Mar 22, 2004 | 06:49 PM
mdhoward@family's Avatar
1.6 roller rockers
I have a 89 GTA 5.7L. Bigger cam than stock, no head work.
How much will 1.6 roller rockers help?
Old Mar 22, 2004 | 08:45 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
10 hp possibly, depending on the cam. you'll notice the difference the moment you crank her up with the 1.6 rr's.
what are your cam specs?
easy math right here:
get your lift intake, divide it by 1.5, then multiply it by 1.6. that'll give your lift. then do the same for your exhaust lift and you're all set
Old Mar 23, 2004 | 06:37 PM
The cam specs are 218/224 duration @ .050, 495/503 lift 112ls
Old Mar 23, 2004 | 10:49 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
JUST MKAKE SURE YOUR VALVE SPRINGS WILL TAKE THE EXTRA VALVE LIFT WITHOUT BINDING BEFORE GOING TO 1.6 ROCKERS!!! (unless you've changed them, they probably won't handle it)
Old Mar 24, 2004 | 02:15 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
then your lift with 1.6 rr's would be .528/.536, and you'll probably gain around 8-10 hp
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
