TPI Injecor Help
TPI Injecor Help
I'm trying to upgrade a TPI unit that was on a 305 to put on a freshly rebuilt 355. I purchased 24# units to replace the 19# ones. When I went to replace them, I noticed the new 24# injectors were shorter than the 19# injectors I removed. When I installed the new injectors, they went into the fuel rail fine, but are set a bit shallow in the manifold. The port for the injector sort of "shrouds" the injector. Is this normal, or do I need to get the longer injectors to do the upgrade? Any help appreciated.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I'm not sure about your particular situation, but when I bought my Accel 24# injectors (a few years ago) they were shorter than the stock ones. I believe my stock injectors were 21# Bosch.
Hope this helps.
Hope this helps.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My Accels had two notches to put the clip in. Make sure that yours are installed on the tallest notch.
Read this: https://www.thirdgen.org/techbb2/sho...ector+diameter
It's kinda long, but it has lots of good info
Sanjay
Aug 12, 2015 03:41 PM
