Putting LT1 Cam Into a Stock LB9 - OK?
Old Mar 28, 2004 | 06:08 PM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Hello All!
I am back in the TPI realm. Been away for awhile, and happy I'm back.
I have an 87 IROC with the stock 305 TPI (LB9) motor and computer and chip. It is and automatic with 2.73 gears. It needs the head gaskets replaced. So, while I have the motor this far apart, and after reading some information on these boards, I have decided to install a LT1 cam from an 95 Z28. I know other changes will also increase performance, but this one I can address now.
My question is this (and YES, I searched the forums before asking!).
Does this cam work with a stock computer and chip? Or will it cause any problems? Will I have any emissions problems?
From my searches, I believe the answer is yes it will work with the factory compuetr and chip, and no it will not affect emissions.
Thanks.
Old Mar 29, 2004 | 10:34 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
ya it will work fine. Since u have ur heads off might as well get them ported n polished or get soem high performance heads and get some headers to get the most out of ur cam.
Old Mar 29, 2004 | 12:40 PM
red87iroc's Avatar
Engine: none
Transmission: none
PHAT:
Thanks for the info. Are you running this combination, or know someone who is?
I may port and polish the heads, but headers will have to wait to be added.
Old Mar 31, 2004 | 09:09 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
no prob
Old Mar 31, 2004 | 11:42 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Not really a combo is it? All you are doing is swapping up to a slightly more aggressive cam, and cleaning up the stocker LB9 heads. I think it should work well because it is pretty basic and safe. For one, the LT1 cam isn't far off from the Lb9/L98 cam, just a little more aggressive. Secondly, the heads are going to be improved LB9s. Everything still matches, but breathing has been significantly improved - nothing radical but you'll definitely see significant gains.
Old Apr 1, 2004 | 10:16 AM
red87iroc's Avatar
Engine: none
Transmission: none
Destroy:
Depends on your definition of "combo". To me, the LT1 cam and LB9 motor is a "combo" because it is not stock, and is a new combination of parts to me.
As to the rest of the post, I thank you for you helpful input on the matter.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
