will these injectors be enough?
Old Mar 31, 2004 | 05:04 PM
sprayed 88's Avatar
Car: 1988 Iroc-z
Engine: L98 350
Transmission: 700-R4
I am running stock TPI MAF, SDPC Vortec intake, Vortech Heads, LT4 Hotcam, 1.6 RR's, SLP 1 3/4" headers, forged pistons, 255lph intank fuel pump. Will 24 # SVO injectors be large enough for this combo? Also, I will have PCMforless burning my chip. What injector constant should I tell them to set? I have heard that SVO's will flow more because of a difference in GM and Ford's fuel pressure. Any help will be greatly appreciated!
Thanks,
Levi :hail:
Old Mar 31, 2004 | 06:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Absolutely, YES. Have the chip burned for 24#/hr injectors. This should ??? force the BLM values to be near 128 or under 128, which I think is what you want.
Also, install an AFPR. By adjusting the fuel pressure, you will be able to dial in the right fuel at WOT. At 58psi fuel pressure, these injectors will flow about 28#/hr and be good for up to 380HP at 85% duty cycle.
The difference in flow rate between these injectors and LT1 injectors is very small, based on 39psi rating VS. 43psi rating. In fact, do a search on flow rate. I believe someone on this board flow check 24#/hr SVO injectors and they came out at 24, not a little higher as was expected, which was 25.2#/hr.
Old Mar 31, 2004 | 08:08 PM
sprayed 88's Avatar
Car: 1988 Iroc-z
Engine: L98 350
Thanks Doc. I am glad that they will work because I just found a guy at corral.net that is going to sell me a set brand new for 125 shipped. That's a whole lot better than new from summit. Once again thanks for the help.
Thanks,
Levi:lala:
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
