Slight Miss
Old Apr 1, 2004 | 04:25 PM
Mgilb18's Avatar
Slight Miss
I have an 86 trans am with a 305TPI. I have a slight miss at lower rpms and don't know what could be causing it. The car has new plugs, wires, distributror cap, rotor, newer fuel pump and a new ecm yet the miss is still there.
Does anyone have any ideas as to what I could try or things I should check?
Thanks for your help!
Matt
Old Apr 1, 2004 | 06:07 PM
tpi_roc's Avatar
Does it happen all the time or when the car is hot?
Old Apr 1, 2004 | 07:11 PM
Mgilb18's Avatar
It seems as though it is always there, but it is worse when the car is hot.
Old Apr 1, 2004 | 07:21 PM
tpi_roc's Avatar
Possibly the ignition module
Old Apr 1, 2004 | 10:35 PM
Mgilb18's Avatar
What is the difference between an ignition module and an electronic spark control module if any? I know that the electronic spark control module sits near the relay bank on the firewall. Where is the ignition module?
Old Apr 1, 2004 | 10:55 PM
tpi_roc's Avatar
Inside of the distributor
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
L98GTA87
Oct 19, 2015 10:43 PM
jerflash
Sep 23, 2015 09:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
