whats this
Old Apr 6, 2004 | 03:11 PM
john_iroc's Avatar
Car: 89 Iroc-Z
whats this
hey, can someone tell me where this connects to and what it is(knock sensor???) cause i'm having cooling problems.
thanks!
Old Apr 6, 2004 | 03:30 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Whereabouts in the engine bay is it situated?
Old Apr 6, 2004 | 03:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That probably goes to the fan switch mounted on the right hand side of the engine. You should have two units there that use a connector like that, the fan switch and the knock sensor. The knock sensor is mounted just forward of the starter and the fan switch is mounted above the starter between #6 & #8 spark plug. The fan switch has a black wire and the knock sensor has a white wire.
Old Apr 6, 2004 | 10:37 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
