biggest camshaft possible in tpi suggestions plz
Old Apr 6, 2004 | 06:01 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
what is the biggest cam lift and duration and lowest lsa possible to install to a 350 tpi stock and have a gr8 hp increase...or any suggestion need to choosse a cam for friday help
i will burn a prom if needed
Old Apr 6, 2004 | 10:02 PM
Raiden's Avatar
Well, find out what the limits are on the TPI intake system and pick a cam that will match the rpm's.
Old Apr 7, 2004 | 01:37 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
For TPI you want a cam for idle to 5,000 rpm. Ported or aftermarket TPI idle to 5500. Really, no more than that you'll be wasting cam and sacrificing power.
Old Apr 7, 2004 | 09:24 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
A lot of guys are running the LT4 hotcam with greta results in the stock TPI situations. If it was a modded TPI I would say a 224/230 or so COMP XE cam. I would probably run a 218/224 XE cam.
Old Apr 7, 2004 | 09:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
more != better
(more does NOT equal better.)
Old Apr 7, 2004 | 10:24 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I believe the TPIS ZZX cam is the biggest made that will work with the computerized TPI. You will have to contact them to confirm it, but I'm pretty sure that is right.
Drag Racers Adage
Some is good.
More is better.
And too much is JUST ENOUGH!
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
midge54
Aug 29, 2015 09:51 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Sanjay
Aug 12, 2015 03:41 PM
