305 TPI w/ LT-1 cam???
Old Apr 7, 2004 | 08:56 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
my 1986 305 TPI is a TURD at the track with a 15.9 @ 85.45 MPH (1/4 mile). that is with SLP runners, Hooker cat-back, and K&N filters. i am geting a new posi for the 10-bolt, which may help the 2.2 sec. 60'.
WHAT SHOULD I SEE WITH THIS SET UP???
ALSO WHAT SHOULD I SEE WITH THE SAME MODS AND A LT1 CAM, DOES IT FIT, WHAT DO I NEED TO DO???
Old Apr 7, 2004 | 09:05 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
I wouldn't expect too much more. IMO the cam is not worth the work or money to install it in a 305. Spend the money on a Nitrous kit, and you will see better gains. The cam will increase power a bit, but you are still getting choked off by the heads, and even the small bore of the motor. A cam is only good if your engine can make efficient use of all the extra air/fuel it will bring in. Plus if you have the stock intake and exhaust manifolds your getting choked off even more...Remeber-Airflow makes power.
Old Apr 7, 2004 | 09:06 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
the reasone i ask is because i can get a LT1 cam for !!!FREE!!! also i am NOT going agressive because i have a 350 block, project 383, which will be a 383 stroker and very agressive. i just need a faster car in the mean time...
Old Apr 7, 2004 | 09:08 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
formula2fast... will i see any kind of incrase, and how much 1/4 mile wize?
Old Apr 7, 2004 | 09:16 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
I am getting a GM crate motor that is the one just like the newer one with the Vortec heads, but instead has the cast "regular" heads, and is rated at 30hp less than the 330hp Vortec headed version. Anyways, its nothing special, but I also have a LT1 that is gonna go in our '36 Chevy, so that means a nice cam is gonna be put in there. Would the LT1 cam go well in my motor? By the time I will get the cam, I will have some good headers, ported everything for the intake, be burnin my own PROMS, blah blah
Old Apr 7, 2004 | 09:23 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
F.U.C.K IT!!! i will do a 350 shot of N2O, iron heads and block will take it, or blow it apart... oooooooooooo well
Old Apr 9, 2004 | 08:02 AM
mikobu3's Avatar
a good cam on a 86 305 tpi will bring your 0-60 down .9 , that is a good gain , also port and polish your heads , my 86 305 tpi transam is at the mechanics getting made fast , i am installing a comp extreme energy #256 212-218 449-456 112lsa also porting and polishing the 416 heads and adding bigger 1.94 intake valves , already got a cai, stock exhaust until next year
by the way my car only has 30 000 original miles , i will let you no in a week or so how my car runs
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
