miniram?
Old Apr 8, 2004 | 11:43 PM
Kandied91z's Avatar
miniram?
those with miniram what are you running for thermostat housing? i'm having problems with my unit since my area is so limited i'm trying to come up with something new and would like to know what the rest of you are using as mine doesn't seal quite right causing alot of problems for me.
once again another wonderful tpis design..
Old Apr 9, 2004 | 06:59 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Make sure that TPIS gave you the CORRECT thermostat housing. They are notorious for giving the WRONG housing to us F-Body guys. Most people I know received the wrong housing. TPIS has a special housing for F-Bodies. The angle is much different in that it points UP a lot. Here is an old pic of my setup which shows the angle the best. Click HERE. Also, if you look closely you can see the big weld where they chopped and rewelded the housing.
Tim
Old Apr 9, 2004 | 07:08 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
ditto to traxion's post. I also got the wrong housing the first time. Call them up and ask for the f-body specific one.
Old Apr 9, 2004 | 02:05 PM
Kandied91z's Avatar
yes i see what your saying...i too had the same thing happen but rather then waiting for them i just had mine fixed. however it isn't the angle or anthing like that. it's the way the thermostat is held in place the ridges are on the housing rather then the intake itself.
see mine is on an almost 90 degree angle because of room...
gixxer92
Apr 12, 2022 12:09 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BWilcox
Sep 20, 2015 12:19 PM
Mutillator
Sep 17, 2015 04:38 PM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
