Which cam is good for me?
Old Apr 13, 2004 | 08:58 AM
Focusonme13's Avatar
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
i have a stock 305tpi....im doin bolt ons....but im going to do a cam....idk how big of a cam, the duration andlift, i should be going.....can someone give me a cam i should use, cuz im going to buy it this week....please help, thanx a lot
Old Apr 13, 2004 | 09:02 AM
87350IROC's Avatar
Car: 87' IROC
If all you want to do is swap cams I would go with the L98 or LT1 cam. If you are willing to get better springs, screw in studs and like then i would get the ZZ4. Springs and studs are still a good idea for the others, however. Also the ZZ4 will benefit from a custom prom.
Old Apr 13, 2004 | 09:07 AM
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
i was thinking of going with a Comp cam KIT, with the new lifters....just i dont know what the stock cam size is in my motor....maybe u know??..
Old Apr 13, 2004 | 01:55 PM
87350IROC's Avatar
Car: 87' IROC
assuming you are talking about the 86' in your side bar you have the horrible peanut cam 178/194 .350"/.385" 109 degree lobe seperation. What else are you willing to do, that will tell us how big of a cam you should get.
Old Apr 14, 2004 | 09:20 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
I may be overlooking something, but the way i read it he has an '85, not an '86.
'85/700R4 (w/LB9 and L69) cam specs are as follows...
Duration @ .050 is 202/206, lift is .403/.415, lobe speration is 114.5, rocker arm ratio is (115/-114).
The '86 cam that I have is ****, duration @ .050 is 179/194
I have the TPI summit cam kit ready to go in, duration @ .050 is 204/214 so there should be a noticable difference.
This wasn't my first choice of camshaft, but since I am a highschool student im on a budget and decided to go with this because it's cheap and will bring my HP up to at least where a stock '85 is at. I'de go with the 212/218 CompCam with an Xtreme energy personally with a mild 305 setup.
Old Apr 14, 2004 | 09:39 PM
87350IROC's Avatar
Car: 87' IROC
i think you are right, in his side bar it says 85, somehow i thought it said 86
Old Apr 14, 2004 | 10:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I agree with ChevyCamaro. With a mild 305 the 212/218 would be a nice cam. You will need to replace the springs and lifters no matter what cam you get. You can't use the LT1 cam or the ZZ4 cam because they are both roller cams I believe. You have to have a flat tappet cam unless you convert everything over which may be to big of a PITA and not worth the trouble.
Old Apr 15, 2004 | 07:55 PM
87350IROC's Avatar
Car: 87' IROC
good point, i forgot he is not roller. Also make sure to install screw in studs. 212/218 will require some prom work to run right.
Old Apr 15, 2004 | 07:57 PM
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
thas ok, thanx for the help, but im not going to go with a cam...i want to try to get into the high 13's with bolt ons, so if u have any ideas what would help me get there.....let me know
Old Apr 15, 2004 | 08:28 PM
87350IROC's Avatar
Car: 87' IROC
start with headers, exhaust, good tires, port the plenum and see where that gets you.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
