Few questions inside, need some help
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
just need to know the stock cam size in my 85 305 TPI
also, what would be a better mod for my tpi, cam or 52 mm TB??
need to know soon, please help, thanx
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
The 52mm won't buy you hardly anything, may even hurt your performance, without any other engine mods. I'd definitely suggest a cam first, and then possibly the throttle body if it needs it. May not even need it then, the 350's run the 48mm throttle body as well, so the 305 may never need a larger one.... maybe with a big cam and a lot of head flow work.
Have a Great Day!!!
- Vern
Have a Great Day!!!
- Vern
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
well i am doing long tube headers, custom exhaust, homemade intake, and pulleys, so i thought maybe the more air would be better than the cam....but im not sure that is why i am asking
I'd still go with a cam first, you'll see a lot more result for your investment. Although be advised if you go to a radically "bigger" cam you may need a TB as well, but I'd still do the cam first.
Good Luck with your build-up!
- Vern
- Vern
Car: 85 Iroc-Z
Engine: 305 Tpi
Transmission: 700R
no im just going with a nice size cam, nothing radical.....i guess i will stay away from the TB until maybe i get some heads, thanx a lot for the help.....i still neeed to find out the stock cam specs now...lol
Iroc8t8
Aug 26, 2015 08:14 AM
