What's the advantage of an AFPR?
Old Apr 14, 2004 | 08:46 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've thought about picking a Holley AFPR for my Car....I've read in Summit and in Jegs about them....but it really doesn't say much about the performance. I know you can adjust your fuel pressure....what does that actually do? Does it make your engine use more gas? How about horse power gains?...or any gains at all? I'm really not into much engine work...just the basic bolt-ons...and this is the very last bolt on if I decide to get one.. If anyone has any helpful info, that would be great. I've done a search...but haven't found what I'm looking for...
Old Apr 14, 2004 | 11:24 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
The way it was explained to me was like this....
Take a spray bottle, squeeze it lightly, then squeeze it hard. You get a much better spray pattern when you squeeze hard. So by increasing your fuel pressure, your pretty much doing the same thing.
This is just what I heard, it could be wrong.........
I also heard after putting on headers, some cars lean out a bit, which an AFPR would come in handy.
Old Apr 17, 2004 | 01:23 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You do get better atomization with higher fuel pressure, but keep in mind that you will also be adding more fuel that the computer isn't expecting (unless you burn a new prom with an up-to-date constant) and it will throw off its fuel calculations.. Granted, bumping it up a few pounds probably won't put it out of controllable range, but the best thing to do would be to burn a new chip...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
djmarch
Oct 2, 2015 10:41 PM
355tpipickup
Sep 4, 2015 05:32 PM
