Good cold/Bad warm starts!
Old Apr 14, 2004 | 12:39 PM
Stan's Avatar
Car: '87 IROC Z28
Engine: 350 HO 330 GM
Transmission: 700r-4
Uh, here's one more for you Guru's. Ol'e red has Good cold starts and Bad warm starts! She start right off in the AM and when i get gas. I thought it was the cap...replaced it. Still have the problem. Any ideas are greatly appreciated....
Stan
Old Apr 14, 2004 | 01:11 PM
Eric's Avatar
Car: 87 GTA
I had the exact same problem. It was my injectors leaking down. After running, the injectors leak the fuel into the cylinders, causing them to flood. That is why it is hard to start, after sitting for a little while. When you get gas, the car is only typically shut off for a few minutes - not long enough to give you any real grief.
I removed the injectors and had them cleaned and it solved the problem.
Good luck!
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
