Lt1 block heads with tpi intake????
Old Apr 15, 2004 | 10:53 PM
Tbird's Avatar
Can the tpi intake be modified to work on the lt1 long block????
Old Apr 15, 2004 | 11:05 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
why not just use the LT1 intake? it would be much easier than trying to get the restrictive TPI to work. Just my .02
Old Apr 15, 2004 | 11:09 PM
Tbird's Avatar
Wouldnt I have to use all the lt1 electronics and swap harness ect....
Old Apr 15, 2004 | 11:41 PM
White91GTA's Avatar
Engine: 5.7L TPI
Are you still running the stock L98 heads? If so then the only way you can use the LT1 intake is if you get it from John Millican or if you want to take the time to mod one yourself to make it work. John's come modded so that they work with stock L98 heads...all wiring and everything is the same.
Old Apr 15, 2004 | 11:46 PM
Tbird's Avatar
lt1 block and lt1 aluminum heads
Old Apr 15, 2004 | 11:55 PM
White91GTA's Avatar
Engine: 5.7L TPI
I don't think you could use the TPI with the LT1 heads due to the fact that LT1's are a reverse flow...but don't hold me to it. I don't know if the intake would really matter, all I know for sure is that if you were using a stock LT1 intake you wouldn't be able to use L98 heads.
Old Apr 16, 2004 | 01:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You will have to drill the LT1 intake bolt pattern on the TPI intake. You would also have to block off the water ports on the TPI intake.
Go out and buy a SBC intake gasket and lay it on your LT1 heads and see what will line up and what won't.
Old Apr 16, 2004 | 07:48 AM
White91GTA's Avatar
Engine: 5.7L TPI
Thanks for chiming in John.
Old Apr 16, 2004 | 09:08 AM
Engine: 4.0L
Because the TPI intake will make more TQ on heavy cars with a STOCK LT1 engine. Perfect example is a Caprice.
Engine: 4.0L
The intake manifold itself doesn't care if you have a LT1 or TPI computer.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Sanjay
Aug 12, 2015 03:41 PM
