TPI timing issues
Old Apr 16, 2004 | 03:45 PM
TPIMonteLS's Avatar
Transmission: Automatic!
TPI timing issues
This isn't simply how to set the timing, read and followed that without much success. Looking for answers regarding timing. Hope not everything timing is banned.
When following the directions, unplug the plug then set timing at 6 advanced. When the plug is back in, ECM reset the timing reads way advanced when checking, is that normal? The car runs like a dog and if its set at 6 advanced WITH the plug connected it seems to start and run stronger. Not sure what my deal is...
What total advance readings do you guys get on ScanTools with your TPI? Idle and at 3000 RPM's ish? TIA. :hail:
Old Apr 17, 2004 | 01:24 AM
Sp0nGa's Avatar
Car: 89 IROC
Engine: LB9
Re: TPI timing issues
Yes it is normal. Ive never done an actual scan to see what sort of timing I was running, but I guess its all what your engine wants is what matters.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
